EAP-TLS question
Apr 16, 2005 3 Replies
Jump to replies (3)
Sorry for the newb question, but I can't find a definitive answer elsewhere.
We are testing EAP-TLS for our wireless, using MS Enterprise 2003 for PKI and IAS. Our AP's are all Cisco 1200's.
The question is: is it possible to use an 1100 AP as a workgroup bridge authenticating via EAP-TLS (the bridge, not machines connected to the bridge). I guess the follow-up question is: how the heck do you get a certificate onto an 1100?
Thanks in advance...
You may wish to investigate the Cisco Aironet Hardware Association Matrix:
Sincerely,
Brad Reese BradReese.Com Cisco Resource Center Toll Free: 877-549-2680 International: 828-277-7272 Website:
runbuh schrieb:
Nope. You'll need LEAP IAS 2k3 doesn't understand LEAP. You can use LEAP against the embedded IOS RADIUS server.
In WGB mode some restrictions (VLAN useage) apply.
