dsl502t and di624s marriage
Jun 07, 2007 1 Replies
i have these 2 units talking and i can access the web just fine. The di624s allows the connection of a fat32 drive via usb and this can be accessed as an FTP drive. If i could figure out how to do it....... Does anyone have the same setup ? i would appreciate some guidence. ta, pete
thread:
Seriously, have you read the documentation/help? (That's where I'd go first.)
Dunno what you mean by "FTP drive". You might have an ftp server running on a host that's accessible via some IP at port 20/21/etc. depending on active/passive mode. Then an "ftp-tree" sub-part of the file-system.
Much configuration is typically possible with ftp servers. And, it might be made accessible from WAN port as well as LAN ports. With authentication via uid/pwd.
Do be careful about allowing anonymous access- crackers will find and try to exploit holes there. And, ftp authentication exchange carries open uid/pwd, a major vulnerability if the packets traverse public networks (i.e. Internet.)
TTFN, J
