do any APs support wpa with 802.11a?
Apr 04, 2005 4 Replies
BradReeseCom
You may wish to investigate WI-FI Certified Products: Brad Reese Cisco Resource Center Toll Free: 877-549-2680 International: 828-277-7272 Website:
do any APs support wpa with 802.11a? open original image
i'm interested in switching to 802.11a because of interference in my condo, but i remain concerned about security. since most APs added WPA after they were released, it's often a vague reference in the changelog and no documentation or screenshots are provided in the user guides.
for example, at
"Added Security support AES/TKIP/RADIUS encryption (802.11g)" this seems to imply it only works via 802.11g.
i'm looking for a good tri-band access point which can support simultaneous 802.11g and 802.11a clients, both using wpa. any suggestions?
this emulator seems to indicate it works with 802.11a...
Sincerely,
Brad Reese BradReese.Com Cisco Resource Center Toll Free: 877-549-2680 International: 828-277-7272 Website:
If you want to block unauthorized users, you might want to try our WIFI internet access blocker at
. It's in beta test stage but it's free...
myWIFIzone said the following on 4/8/2005 1:02 PM:
Has anyone tried this?
