DD-WRT Will not display LAN/WAN IP just 0.0.0.0 for everything!
Sep 10, 2006 1 Replies
Login TypeAutomatic Configuration - DHCP Login Status IP Address0.0.0.0 Subnet Mask0.0.0.0 Gateway0.0.0.0 DNS 1 DNS 2 DNS 3 Remaining Lease Time0 days 00:00:00
Also since I didn't do the MAC ADDRESS imaging thing, the MAC Address of my router is the DD-WRT default: 00:40:10:10:00:02 . Is there anyway to fully start over and go back to the original Linksys control panel or atleast to fix the DD-WRT configurations?
I would appreciate any help at all. Thank you in advance!
What you are experiencing seems to be normal behaviour when DD_WRT fails to find a DHCP on the WAN port. ie. you are not connected to the net or the WAN port is unplugged or there is no DHCP present on the network plugged into the WAN port (labelled "Internet" on the WRT54GL)
The MAC address is printed on the sticker underneath the unit. You can easily clone the MAC address by going to this page:
http://192.168.1.1/WanMAC.asp Login etc..
Hope that helps...
