dd-wrt ntp command
Jun 26, 2006 2 Replies
Anyone know the startup command for dd-wrt to synchronize with an ntp server? I'd like to add it to cron.d.
"skdjfa" hath wroth:
/usr/bin/ntpclient -c 1 -s -h us.pool.ntp.org
However, there's a problem. The WRT54G clock drifts rather badly over short periods of time. If you run ntpclient from cron every hour, your log files will be a mess. See discussion at:
clues. Also see:
