Bridging a Netgear WGR614 with a Belkin F5D7230-4 - possible?
Dec 25, 2007 1 Replies
Jeff Liebermann
Nope. Wireless routers and access points are made to talk to client radios, not each other. If both routers had the WDS (wireless distribution system) protocol support, they would be able to talk to each other. However, if you want to run a CAT5 cable between the two routers…
I've got a Netgear WGR614 as my "main" router plugged into our cable line. I also have an old Belkin F5D7230-4. I want to make the Belkin connect to the Netgear from another part of the house so I can plug a non-wireless computer into it to get on the net.
My question is, is it possible to do this at all?
Thanks for your time.
rmwebs hath wroth:
However, if you want to run a CAT5 cable between the two routers, using one as a wireless router, but the other as just a wireless access point, that will work.
