Belkin7630 -no reboot after power cut- ideas?
Feb 23, 2005 0 Replies
Thanks I will try and get an appropriately-rated PSU and try it
Andrew Sayers Wrote:
organic333 wrote:
> >When I had a power cut, or when I unplug the router at the mains (at
> the
> >surge protector) the router does not reboot - no LED's on at all
> >although the power is attached. But when I unplug and re-plug the low
> >voltage power cable at the router, it reboots fine.
> >Problem is - when I am accessing the router remotely, I am not there
> to
> >unplug its little lead!
> >Belkin support said "get latest firmware" - no difference, what a
> >surprise!
> >Any ideas anyone?
> I'm no expert, but it sounds like a PSU problem. Is there an external
> PSU between the
> wall socket and the router? If so maybe this could be the cause - can
> you try a
> replacement/generic one to test this?
> hope this helps
> Andy Sayers - Lincolnshire, UK
> If you'd like to reply to me, then please
> use the newsgroup, email address is fictitious.
