antennas & access points
Jul 18, 2006 2 Replies
I'm trying to extend the range of my home network by putting a directional antenna on an access point.
What do I need at the remote end to communicate with this directional antenna? Will another access point work? I was hoping to put another directional antenna at the remote point so that the two directional antennas point toward each other.
Thanks for your help.
For a single PC you just need a regular network card. For a group of PC on a lan you want something like a wireless Bridge.
On Tue, 18 Jul 2006 15:39:05 -0500, "Jim" wrote in :
Standard wireless adapter or wireless client bridge.
No.
That can indeed help if you need the extra gain. For a simple commercial solution, consider the Hawking HWU8DD
