Does anyone know how to report this AirSnare coding error to developers?
AirSnare version 1.5.0 Error: An error has occured while attempting to place the interface in monitor mode. Please take the time to report this to us. Adapter #:(1)Intel(R) PRO/Wireless 2200BG Network Connection (Microsoft's Packet Scheduler) Error Num: -2147220982 Error Des: Procedure PacketSetHwFilter failed. Error Code = 0
A friend suggested I download AirSnare to prove which of my neighbors is connecting to my wireless Internet router so I downloaded AirSnare, Ethereal, and WinCap as per instructions and installed onto winxp.
Do you know what this error is indicating? How do we report an error to the AirSnare coding team?
Hello,I have two dell laptops and one desktop. Desktop is connected torouter...
M
Mike
In message at 09:45:55 on Sun, 17 Jun 2007, pamela.higgins wrote
If you have the proper protection on, why worry about it?
C
Craig
I'd start on their forum. The forum is pretty active and is hosted at
Nope
hth,
-Craig
P
Præthön
You can contact the developer Jay Deboer on the email address jaydotdeboeratcomcastdotnet. Just replace the dots and at with the genuine article!
Stuart
F
Flyer
Better to employ security on the router to prevent the connection in the 1st place.
P.
J
Jeff Liebermann
Mike hath wroth:
Do you just lock the front door and assume that the lock is in working order? Do you even look at the lock to check if it's functional? Are you sure the "proper protection" is working, or perhaps your neighbor has a spare key?
It's the same with any kind of network security, including wireless. If you don't monitor the connection, you don't have any clue of what's moving on your network or who's using it. For example, I've tracked down a few virus infections to the neighbors using the allegedly secure wireless connection, and accidentally spreading a virus to open shares. I've also seen internet performance come to a grinding halt when the local brat does his file sharing exercises. Without monitoring, one would never know these things were happening, except perhaps by the symptoms, which could be attributable to other causes.
As Prez Reagan often said; "Trust, but verify".
K
Krazee Brenda
Condomware
K
Krazee Brenda
Chastitybeltware?
K
Krazee Brenda
Fuckheadware
S
Si
get on touch with them, I doubt they read this group.
Your neighbour wouldn't be connecting unless you were stupid enough not to set your security correctly. Did you give them the WPA-PSK key? If so, just change it and use your MAC access list then change your SSID and hide it.
Not bothered looking as your friend should have advised you to set your router correctly instead of messing about with software you (and him) don't understand and don't even need. God knows how you would attempt to prove it was a neighbour connecting to your system! Think about it a bit more. The police would laugh at you as you can't even use a computer or router, the neighbour would tell you to go away.
You contact them.
S
Si
Yes, when the door doesn't open I can say the lock works.
Yes, when the door is locked and checked.
The only way a neighbour would have that is if they were given one by the occupier and told to use it.
You do if you use WPA-PSK and don't give people the key, no one else will be connecting and using it. Even better if you use a decent firewall.
You obviously lie aswell! That statement is rubbish and you can't even back it up. With proper security you would not be able to monitor their connections and certainly couldn't see what was going on between their PC and web sites. You might have told your neighbours that in order to be given access to their PC and obtain confidential details from it, something I would hope your neighbours now do something about.
Well again that is rubbish if people use different channels. Why would you be feeling the need to get involved with data being passed between a router and a PC. You only assume it is file sharing as the data is encrypted so YOU CAN NOT SEE what that user is doing. You can lie all you like and make as many false claims as you like to sound impressive, but most of us know you're wrong.
That is a meaningless statement, just a collection of words with no real meaning. It is very vague and empty, like your understanding of computers, RF, wireless networks and computer security. Get back to your "hacker" group!
S
Si
I just tried that forum and it's obviously a joke, with the amount of adverts and p*rn in the titles of messages. No serious discussion going on and NOT ONE user has ever used it to detect anything as that part of the forum has no posts! As I suspected, a waste of time downloading or using the program. It might have been OK in the days of WEP, but no longer of any use with WPA-PSK.
B
Bear Bottoms
Diaphramware?
K
Krazee Brenda
HooverDamware and dam uncomfortable.
K
Krazee Brenda
Police Geeks?
B
Bear Bottoms
AsperinHeldFirmlyBetweenTheKneesware.
N
News Reader
I think you will find this is a generic "error" message as such, not really requiring reporting to the coders, but more research by yourself about your hardware, and whether it has drivers that support monitor mode in Windows, etc., etc.
You may find you need to use special drivers, or use the device under Linux, or use different hardware. Probably not actually a software problem as such, and probably not something really needing reporting to the software writers (I expect the please report this to us bit is shown in all their software's error messages). A bit more reading about this software, your hardware, drivers, reference drivers, monitor mode, etc., will probably reveal this as a very common problem requiring your attention in other areas. A bit (or more accurately somewhere between quite a lot and a lot) of reading and research on your part, around this subject, software, your hardware and its drivers, etc., should provide you with a more meaningful understanding and answer, etc.
This isn¢t a good error. This is telling you that the software is having problems putting your network card into promiscuous mode. Basically your card isn¢t compatible. Your only option is to try a different card.
Report Content
ASAP.
