2 Routers (4 port plus 4port w/wireless) home network
Jan 01, 2006 19 Replies
Jump to replies (19)
2 Routers (4 port plus 4port w/wireless) home network open original image
I want to set up a home network using:
- cable modem that connects to 4 port Linksys router that connects to a
4 port DLlink wireless/4port router
- 3 computers plus the DLink are hooked up to the Linksys
- 2 computers plus a wireless are hooked up to the DLink
Not sure if I created a mess, but only the computers hooked up directly
to a router see each other, but NOT the computers that are on the other
router.
Can I make the routers "see" all computers?
Or: how else can I hook up 5 computers + 1 Wireless with this hardware?
I guess the pros will tell me: hook up the wireless/4port router to the
cable modem, then plug in a regular hub (not a router).
I am guessing that routers effectively "block" what is behind (almost their purpose). But since I have these 2 routers, I thought I can use one as a hub.
Can a router be "made" to act as a hub, maybe switching firewall or other stuff off?
"Duane Arnold" hath wroth:
Medium
you trim the ultra long Linksys URL's down to just the document ID number, it will also work. That works for their "Easy Answers" (knowledge dump) URL's but doesn't work for URL's on their product or download web piles.
Your D-Link can probably be made to act as a switch.
Turn off DHCP on the D-Link (and any other firewall/filtering you can). Connect from the Linksys to a LAN port on the D-Link.
DHCP must be enabled on only one router, preferably the one connected to the modem.
__modem__[wan]router[lan]__[lan]router
You may need to use an uplink port or a crossover cable to make the router[lan]__[lan]router connection.
Duane Arnold wrote: I got
Check out the WiFlyer at
Lets me use my wireless laptop/even with dialup (wirelessly), so I can stay in bed and surf... :)
Can someone send the same details for the DLink Di-524? I found "Static IP" (vs. switching off DHCP)? I was then ask to fill in a primary DNS (where would I get that from?). Should I just put in like 255.255.255.0?
Also: I remember there was a nice dos command that I could enter into the "run:..." line in XP, that showed me all the settings. It was NOT ipconfig, but more something like wincfg or so. Anybody know what I am talking about?
"Volker" hath wroth:
IPCONFIG /ALL
WINIPCFG is for Windoze 95/98/ME. WNTIPCFG is for Windoze 2K and XP. For W2K, download from: |
's included with Windoze XP.
You might wanna also grab NETDIAG for W2K. It's included with XP. When run from the command line, it shows quite a few network configuration problems. |
Lots of other tools are included (and well hidden): |
An ipconfig/all on an Internet-working machine will give you the DNS server addresses.
Long
**&p_li=&p_topview=1 Short
You make the adjustments in the instructions based on what router is going to be the gateway and which one will be the switch after truning off DHCP.
Duane :)
William P.N. Smith hath wroth:
For XP, it's not in the "resource kit". It's in the "support tools". The names have been changed to confuse the innocent.
Find the original XP cdrom and dive into: E:\\SUPPORT\\TOOLS\\ directory. Run SETUP.EXE program. Tell it to install everything.
To run: Start -> Run -> CMD netdiag /v | more Lots and lots and lots and lots of info mixed with gibberish.
In the case of Windoze 2000, the installers dump everything into: C:\\PROGRAM FILES\\RESOURCE KIT\\ There are some HTML files with usage documentation in this directory. No clue where MS dumps it for XP.
> If you trim the ultra long Linksys URL's down to just the document ID
You told me that once before. I just couldn't remember it. I got enough to do just remembering to get out of the bed in the morning.
Thanks
Duane :)
But maybe only if you've installed the resource kit?
No, you were misled.
You must turn off the DHCP _server_ but you can still get your IP via DHCP (and it will get it from the other router). But the second router must connect from a LAN port, not the WAN or INTERNET port, to the first router.
Why not do the following?
__[wan]modem/router[lan]__[lan]router[lan]__[lan]router
Using all lan connections, that sounds correct. Are you sure that's a lan-to-wan connection between the first and second routers? The addressing you mentioned should be incompatible with such a topology.
A static IP to do what? This thread is about connecting two routers together. So what is your intent with this Static IP?
Duane :)
The Extened Stay America Inn I am at while on the road has wireless and I won't even use that. :)
Duane :)
Here is one setup I have assembled with 3 routers.
__[wan]modem/router[lan]__[wan]router[lan]__[lan]router
(Speedstream 5861)_______SMCwirelessrouter____100ftCAT5___SMCwirelessrouter IIRC The 2 SMC routers both have their DHCP disabled, but the 1st SMC got it's LAN address changed to be included into the 5861's LAN's IP range and the second just has a static WAN IP address that is also in the 5861's LAN's IP range. I probably made this too complicated but it works, I can move files between computers and share a printer on 1 computer!!! ;-)
I needed/wanted to set up the two wireless routers to have 2 wired & 1 wireless accesses to the network. The first SMC router has a very limited transmitting range.
later, dave (One out of many daves)
No you are correct Dom, it is a lan to lan connection between the first and second router and also between the second and third router. I just checked it today. later, dave (One out of many daves)
Speedstream-5861[lan]__[wan]SMCwirelessrouter[lan]__[lan]SMCwirelessrouter
