Web Frontend
Mar 16, 2005 4 Replies
Jump to replies (4)
You could use a service with a JAVA ap for VOIP, such as Glophone's Glo2go. Put a shortcut on your page for the loading page.
****************WARNING! DO NOT login to Glo2Go Express if you are using the same PC on which your GloPhone software is installed. Doing so will cause Glo2Go Express to replace your GloPhone
This can be used on PCs when downloads/ installations are restricted, such as library computers.
I would like to use my VOIP account on every computer in any internet cafe of the world. For that I am searching for an free web frontend, which I can implement in my homepage. Does anybody know such a solution or even has experiencein using such an front end.
Thanks for Your help
Josef
"Josef Wagner" wrote in news:423755bb$0$6882$ snipped-for-privacy@news.freenet.de:
Another possiblity is to purchase a SIP gateway (pocket sized device) and carry that around. When you find an internet cafe, ask if you can plug the device into their network to make the calls.
I guess it would depend on your provider and the lan setup on every cafe internet, wether its ip addresses are set manulay or by dhcp, it woluld be easier with the latter.
has a beta program to use their free account from any computer in the world.
Pedro
Yup. FWD can work. Check my post in
for link to other soft
clients if needed.
