Why not test it with a friend? My cable connection just tested at 641K, it works fine. I have friends who use softphones at dialup speed. at least you will know what is "possible".
Hi
for you is possible to use a Voip softphone with a
Which is for you the minimum required as DSL connection and which is the bandwith taken if we speak to the phone together (the caller and the called) ?
thank you for the support
Depending on compression used, it is possible to have an (arguably) decent quality call utilizing only 8Kbit/sec, so you should do just fine with your DSL provided by you do not download Win XP SP2 at the same time. Thanks, Microsoft for a 75MByte patch!
Try
Also, what is the upstream speed?
