Voip on Satellite Phone
Feb 26, 2006 3 Replies
Jump to replies (3)
Is it possible to do Voip on a satellite phone without a satellite dish ? If so i would appreciate the help . Done google already.
Look for Inmarsat BGAN or Inmarsat RBGAN. These products support VOIP over satellite without a satellite dish.
-- EventStudio System Designer 2.5 -
Systems Engineering and Call Flow Design Tool
you can use direcway also for this.
with the VAP Appliance you can connect VAP to Phone and VAP will connect to to antena ( terminal of direcway from HNS). then you can do voice over IP and even internet browsing over the satallite link. this is very popular in USA. these is no dish involved but a small antenna you need.
Regards
