VoIP across 802.11b/g connection
Nov 27, 2005 2 Replies
follow up to...?microsoft.public.win2000.networking?
I just did a test for VoIP and the resuts, while not fantastic are:
URL:
: Sun Nov 27 19:01:33 GMT 2005 Download: 390,152 bps Upload: 333,472 bps QOS: 58% RTT: 96 ms MaxPause: 296 ms Test #: 926791
and
URL: Sun Nov 27 11:01:05 GMT+00:00 2005 Download: 517,400 bps Upload: 266,904 bps QOS: 60% RTT: 96 ms MaxPause: 301 ms Test #: 926807
The first is from the gateway computer, the second test from a computer which connects to the gateway. The gateway is arrakis, the other computer is named geidiprime.
1.) is the speed sufficient for a Linksys phone adapter (PAP2) to connect to this network?
2.) is there anything which I need to do before connecting the PAP2 to this network?
The arrakis box uses a wi-fi connection, specifically an Asus WL-330g wireless ethernet adapter/NIC to connect to the SMC7004VWBR wireless router. Double NAT, but it works for the computers. Will it work for the VoIP PAP2?
C:\\>ipconfig /all
Windows 2000 IP Configuration
Host Name . . . . . . . . . . . . : arrakis Primary DNS Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Broadcast IP Routing Enabled. . . . . . . . : Yes WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter 3com:
Connection-specific DNS Suffix . : Description . . . . . . . . . . . : 3Com EtherLink XL 10/100 PCI For Complete PC Management NIC (3C905C-TX) Physical Address. . . . . . . . . : 00-50-DA-68-8C-B2 DHCP Enabled. . . . . . . . . . . : No IP Address. . . . . . . . . . . . : 192.168.0.1 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : DNS Servers . . . . . . . . . . . :
Ethernet adapter SiS:
Connection-specific DNS Suffix . : Description . . . . . . . . . . . : SiS 900 PCI Fast Ethernet Adapter Physical Address. . . . . . . . . : 00-0A-E6-A0-24-27 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IP Address. . . . . . . . . . . . : 192.168.2.175 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 192.168.2.1 DHCP Server . . . . . . . . . . . : 192.168.2.1 DNS Servers . . . . . . . . . . . : 192.168.2.1 Lease Obtained. . . . . . . . . . : Sunday, November 27, 2005
8:53:04 AM Lease Expires . . . . . . . . . . : Sunday, December 04, 2005
8:51:50 AM
C:\\>ping 192.168.0.2
Pinging 192.168.0.2 with 32 bytes of data:
Reply from 192.168.0.2: bytes=32 time C:\\>ipconfig /all
Host Name . . . . . . . . . . . . : geidiprime Primary DNS Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Broadcast IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Dlink:
Connection-specific DNS Suffix . : Description . . . . . . . . . . . : D-Link DFE-538TX 10/100 Adapter Physical Address. . . . . . . . . : 00-0D-88-37-FA-22 DHCP Enabled. . . . . . . . . . . : No IP Address. . . . . . . . . . . . : 192.168.0.2 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 192.168.0.1 DNS Servers . . . . . . . . . . . : 192.168.0.1
C:\\>ping 192.168.0.1
Pinging 192.168.0.1 with 32 bytes of data:
Reply from 192.168.0.1: bytes=32 time
I'm no pro at this but did set up IP phones here at home wirelessly. Between 2 routers (with external antennae) that are 2 miles apart, at
11b and about 4-500KByte/s up-and-down speeds the phone line was occasionally breaking up. When I changed to 11g routers, I'm now getting over 1MByte/s up-and -down, and line quality is much better. May I suggest you go over to alt.internet.wireless and ask this same question with all the details you've posted here. I'm sure they'll give you some good advice.
URL:
and
1.) is the speed sufficient for a Linksys phone adapter (PAP2) to connect to this network? 2.) is there anything which I need to do before connecting the PAP2 to this network?
C:\\>ipconfig /all
8:53:04 AM Lease Expires . . . . . . . . . . : Sunday, December 04, 2005 8:51:50 AM
