speed of internet connection for VoIP
Jul 13, 2005 8 Replies
Jump to replies (8)
speed of internet connection for VoIP open original image
my internet connection isn't always the best, but I'd like to do VoIP. Is there a test to see if the connection is fast enough?
[thufir@arrakis ~]$ ping
PING
(66.102.7.147) 56(84) bytes of data.
64 bytes from 66.102.7.147: icmp_seq=0 ttl=244 time=60.0 ms
64 bytes from 66.102.7.147: icmp_seq=1 ttl=244 time=58.0 ms
64 bytes from 66.102.7.147: icmp_seq=2 ttl=244 time=91.2 ms
64 bytes from 66.102.7.147: icmp_seq=3 ttl=244 time=60.3 ms
64 bytes from 66.102.7.147: icmp_seq=4 ttl=244 time=59.7 ms
64 bytes from 66.102.7.147: icmp_seq=5 ttl=244 time=91.3 ms
ping statistics ---
6 packets transmitted, 6 received, 0% packet loss, time 5004ms rtt min/avg/max/mdev = 58.028/70.143/91.371/14.996 ms, pipe 2 [thufir@arrakis ~]$
this was ok, but sometimes I get 25% packet loss, or higher.
thanks,
Thufir
The variance (58-90ms) is not great.
Neither is that.
I have 300ms ping times to my VoIP server but there is no packet loss and the ping times are extremely stable. VoIP works great for me.
miguel
and select Speed Test. You will need Java enabled.
Requirements for a call using G711 is approx 80k in both directions.
Ivor
Miguel Cruz wrote: ...
What's wrong with the variance? Does that mean that packet1 might arrive after packet2, something like that? I suppose that happens no matter what, so maybe if the variance is too over too great a range then...?
I did some of those java tests, and I think VoIP will work in my case, at least sometimes. There may be times when it won't work, but that's ok for me.
-Thufir
John S. wrote: ...
This connection is wi-fi. The router, an SMC7004VWBR has a broadband (cable) connection. This computer uses an asus wl-330g to connect to the router. The VoIP would be routed through this computer. (Or, the wl-330g might plug directly into a hub, and the VoIP adapter to the hub, I'm not sure yet.) It's hard to pinpoint the problem areas with regards to reliability and performance. It might be the cable network, it might be the wireless connection, it's hard to say. It doesn't have to be super reliable, I don't like phones anyhow ;)
-Thufir
Basically if you have DSL or Cable, you are fast enough.
Reliability is another issue.
Dear Friend,
Most of VoIP Service providers require fast Internet access.
But with Ubifone (
) you can start at dialup speed, meaning from 56 KB.
Kind Regards,
Sam.
------------------------------------- snipped-for-privacy@gmail.com wrote:
##-----------------------------------------------## Article posted with Cabling-Design.com Newsgroup Archive
read and post WWW interface to your favorite newsgroup - comp.dcom.voice-over-ip - 4876 messages and counting! ##-----------------------------------------------##
Thanks, but I think that I'll be able to make it work with regular VoIP.
-Thufir
