SIP Technical Overview
Feb 03, 2005 7 Replies
Jump to replies (7)
SIP Technical Overview open original image
I am in the process of deploying VOIP at a number of office locations. My initial efforts have been somewhat disappointing, due to voice quality problems.
I am trying to get a better understanding of how SIP works, so I can figure out where the network bottlenecks are that are causing my voice problems.
Does anyone know any good links to a detailed technical explanation of how calls are handled by typical VOIP providers (Vonage, Broadvoice, etc...)? I am particularly interested in the question of how SIP proxies work (i.e. does all the voice traffic flow thru the proxies, or do they just initiate sessions and the two VOIP endpoints communicate directly). Also, how do SIP terminal adapters work when they are located behind NAT routers?
Thanks,
Look at what codecs you are using, what the link delay and jitter are, and work from that.
You want minimum delay and jitter. Sometimes the lower bandwidth codecs help in that you can run a link at lower than max capacity to improve the link performance.
Don't share VoIP and internet traffic through the same bottleneck!!!
.... And then you can play with VLANs and QoS...
Good luck, Martin
i have found the following site is very useful:
That may depend on insufficient bandwidth causing high dropout rate. Mixing voice and data streams on the same link, without either plenty of spare capacity or some QoS
) mechanism to prioritize the voice packets, is going to yield poor results.
Start here:
SIP allows each endpoint to determine, among other parameters, the IP address where to send the RTP stream. Usually this is the other endpoint's address, but occasionally there could be other devices in the middle (firewalls, NAT routers, RTP proxies etc.).
It depends :-) . Read here:
(ICE)
(STUN)
(TURN)
Most modern devices implement STUN client capability, but as far as I know very few support TURN/ICE.
Enzo
Why hasn't anyone mentioned
? It has EVERYTHING to do with VoIP, an excellent resource :)
-Paul
Voice Quality impairments have a lot of different causes. Check out
and
It covered quality of voice, but NOT Quality of Service (QoS) which I think is the #1 problem when adding VoIP to existing systems. Ignoring QoS is a major shortcoming of that web site.
