Seeing unexpected skinny heartbeats when sniffing IP phone's network traffic
Aug 24, 2005 5 Replies
Jump to replies (5)
I am doing research to see if an application on a computer that is connected to the network port of an IP phone (7940/60/70/etc) can "see" the attached phone. I am doing this by using a packet sniffer to look for skinny heartbeats between the phone and CallManagers in a cluster. I am seeing the skinny heartbeats for my attached phone, but I am also seeing heartbeats and acks between other phones and other CallManager clusters. These are TCP packets with IPs and MACs that do not match my phone or PC. I don't understand why I am even able to see these packets. My phone (and the others that I see heartbeats from) are all attached to a 3548 switch which is connected to a core Catalyst 6000 switch.
Does anyone know what could be causing my sniffing application (Ethereal) on my PC to be able to see TCP traffic that is not even directed to my phone or PC? (There are no SPAN sessions on the switch. There is no hub between my PC, the phone, and the switch. This is recreatable and persistent.) I can provide additional information if needed.
Thanks in advance.
Probably the fact that Ethereal is sniffing with its interface put in "promiscuous mode", and your switches are (mis-?)configured to work as non-switching hubs...
Enzo
Are they directed to broadcast addresses?
miguel
In reply to Enzo's message: I am sniffing in promiscuous mode so I can see the traffic going to and coming from the attached IP phone. I do not believe the switches are misconfigured. They are not acting like hubs (except in the cases where I am seeing these misdirected packets).
In reply to Miguel: The packets that I am seeing are not broadcast packets. They are directed to specific IP addresses and MACs that do not include the IP phone or the PC I am using for sniffing. I am seeing other broadcast traffic, but I am ignoring that.
The latest theory on this is that it is Unicast Flooding. This is supposedly a normal occurance when the switches MAC table gets filled up. When the switch has a packet for a MAC, but can't find the MAC in its table, it sends it out all its ports; not as a broadcast packet, but essentially a broadcast because it is sent out every port. We have looked at the MAC table in both switches and they are far from being full, so I don't know about this being the cause. I am continuing to look at the switch settings and Unicast Flooding to see if I can find an answer.
Thanks for your responses!
If the MAC table is not full then this seems unlikely. Also, unless there is nothing else happening on your network, you would see other traffic also coming out all interfaces, not just the VoIP stuff.
miguel
We are seeing a smattering of other TCP packets that I shouldn't be able to see. I've been concentrating on the skinny heartbeats because that is what I was more interested in.
