why do my pc see voice traffic
May 17, 2006 4 Replies
yvanog
Can you verify that your phone is in fact getting the proper VLAN assignment? We hardcode or VLANs in the phone. I believe your phone is in the wrong VLAN (or somewhere there is a VLAN misconfig). On a side note, I use Polycom phones and they are switches, not hubs..does Cisco…
why do my pc see voice traffic open original image
The computer is behind a 7940 ip phone, each directly connected to a
3550 PoE switch. (switched network) they use different vlan
See config on the Access switch
interface FastEthernet0/2 switchport access vlan 20 switchport mode access switchport voice vlan 21 mls qos trust device cisco-phone mls qos trust cos auto qos voip cisco-phone spanning-tree portfast
on the 6500 multilayer switch
mon-rs-01#sh ip int brief Interface IP-Address OK? Method Status Protocol
...(truncated)... Vlan20 10.1.20.2 YES NVRAM up up Vlan21 10.11.20.2 YES NVRAM up up
When launching Ether Real from my computer, and selecting the promiscuous mode options, I see all traffic from the phone devices talking to other phones or other voice application servers. I never had this before, and I should not.
I m wondering it it s not a config somewhere in the ip phone ? wich would work like a hub.
Any ideas ??
Can you verify that your phone is in fact getting the proper VLAN assignment? We hardcode or VLANs in the phone. I believe your phone is in the wrong VLAN (or somewhere there is a VLAN misconfig). On a side note, I use Polycom phones and they are switches, not hubs..does Cisco set their devices up differently (meaning they are true hubs)?
This is done by the phone, not the switch. To turn off the voice traffic from being seen by the PC, in CallManager, under the phone configuration, set "PC Voice VLAN Access" to disabled.
Scott
in fact it is the solution.
thanks
but i couldn' acces your link. it asked me for credentials.
i guess that cco credentials are different from cisco.com guest as i am.
In some cases you can just take out the "customer/" component.
This one is OK.
There is BTW also a "partner/" directory that is also secured and can be removed sometimes too.
