Cisco 1605 Console
May 16, 2006 1 Replies
I pick-up a 1605-R off ebay. I've got a T1 coming in about 2 weeks for our Asterisk server. I tried to get it to talk to me using 9600,
8 bit, 1 stop no flow control (hyper terminal) and I see nothing during boot or afterwards from the console port. I assume the cable is standard RS-232. The cable works with other devices. The lights seem normal with OK after boot. Any ideas I should try?
Bart
Have you searched Cisco's site?
It is not clear whether your serial and, or console cable working fine with other Cisco devices.
If there no help available at Cisco, try starting with 1200 baud and go up one by one 2400, 4800, 9600, 19200, 38400, 57600 and 115200 on live
1605 box, in none of the above brings your any connectivity you may need change your cable between cross and, or straight models (Hint: test your current cable with a multi-meter, it should be a _cross_ if all the pins are not 1 is to 1, straight otherwise).
Though not related to Cisco devices, but you may find good information on standard serial cables, particularly the Pinouts and Signals at:
Hope that helps,
