ATX Redundant Power Supply for Asterisk
Apr 02, 2005 4 Replies
Jump to replies (4)
I am building a Asterisk based PBX. Does anyone know where I can get an inexpensive redundant power supply for a standard ATX PC chassis? Thanks!
Eric
Most redundant power supplies require a chassis that supports it. A regular ATX chassis is probably not going to work. That is, the usual cut-out provided on most ATX chassis won't have the right clearance to allow use of a redundant power supply. The hole needs to be pretty large. But if yours has one searching google brings up results:
A quick check doesn't indicate any of these will work in 'standard ATX' chassis.
Most redundant power supplies are designed for rackmount chassis.
Take a look at the following redundant power supply installation tutorial.
You might have to change your PC chassis to a rackmount chassis.
Hi.
I have never had a problem with power supplies failing, As long as you are using a quality case and power supply. Personally you should be looking at true server grade cases an power supplies such as Intel compaq etc. Remember if you are using redundant power you should use two UPS's. Have a look on ebay and you should get a quality server for a fraction of the new cost and it will be more relaible than any PC.
Ian
Your best bet would be to watch ebay for an Intel Cabrillo-C case--new they were about 1500 bucks but you can find them on ebay for a very reasonable price these days. That gets you a triple-redundant power supply (assuming it has all three modules installed) in a purpose-built server case for a less than you'd pay for dual-redundant alone.
