Panasonic KV-TD816 programming
Sep 19, 2004 1 Replies
I have the Pansonic Digital Hybrid System. I need to do a system reprogramming of a flexible CO (program function 005). The manual says that I need to call a dealer, but I really don't want to get involved with that. Does anyone have a suggestion on how to do this or where to get info. Panasonic will not give out the info (you need to be a dealer). Thanks.
Jim
I've never heard of a KV-TD816. If you mean KX-TD816, you can get the programming manual from Panasonic at 800-833-9626. It is part number PSQX2145ZA and costs $55. Ablecomm also sells them at
. You can find information about 005 programming here:
