Re: Virtual Strip Searches Begun at Phoenix Airport
Feb 27, 2007 0 Replies
Terry Tang wrote:
>> "It's 100 percent voluntary, so if the passenger doesn't feel
>> comfortable with it, the passenger doesn't have to go through it," TSA
>> spokesman Nico Melendez said.
> Oh, sure, just go to jail instead.
BZZT! Thank you for playing.
You have the choice for the machine inspection or a 'pat down' search.
If you don't choose to submit to either, you have the choice of not flying.
There is no risk of jail.
[TELECOM Digest Editor's Note: But, let's cut to the chase, shall we? You have the freedom to travel about the United States in a reasonable and timely way, or your choice is stay at home or go to jail. PAT]
