Re: Using Two ADSL Internet Connections Simultaneously
Dec 19, 2005 0 Replies
>> Obtain a Linux server, connect each DSL line to a separate Ethernet
>> card, and modify its route table to give equal weight to each line.
>> You'll need a third card for your wireless AP or other LAN connections.
> This approach only solves "part" of the problem, namely 'outgoing' > traffic.
> "Incoming" traffic is an entirely different problem. And
> load-balancing _that_ traffic cannot be done in anything approaching a
> satisfactory manner without 'help' from the 'upstream' end. And it
> requires that both DSL circuits terminate at the same 'upstream' > provider.
There are techniques for balancing (or optimizing) incoming (using NAT to set up each connection to use the better available IP address for _it_).
>> I know nothing about setting up a server, so please pardon my
>> ignorance. Is there any reason why it needs to be a linux server?
> No, it *doesn't*have*to*be* "Linux".
But if you have to ask, you shouldn't be doing it.
Seth
