Re: Two VOIP Boxes on the Same Port
Aug 21, 2005 0 Replies
Details of 'fixing' the situation depend on the gory details of your
> set-up. Do you have multiple IP addresses available to you? Or only
> a single address? Are you using DHCP? Are you using NAT/PAT?
> Depending on those answers, you _may_ be able to do the necessary
> things entirely in the Cisco 831. Or, you may have to access the
> configuration stuff for the VoIP devices.
No, I only get a single IP address on my Mediacom cablemodem.
Yes and no. I have a virtual DHCP server in my Cisco 831. But all of the permanent devices on my home network have private/static IP addresses assigned to and programmed into them.
Yes, I am using NAT/PAT.
Can you suggest a solution?
Regards,
Fred
