Sipura 3000 via Cisco 831 on Voicepulse VOIP
Jun 18, 2005 1 Replies
I just got a Sipura 3000 VOIP adapter. I've connected it behind my Cisco 831 router and am connecting to the Internet via Earthlink to Voicepulse.
I get a constant busy in this configuration. As an experiment, I connected the Sipura 3000 directly to the cablemodem and reobooted both of them (after powering down the cablemodem for more than thirty seconds). The unit worked. So, I put it back to normal and I get a busy signal every time I pull up that line.
I contacted Voicepulse. They told me that my Cisco 831 router was blocking the SIP on port 5060. I've installed both of these:
ip nat inside source static udp 10.10.10.232 5060 interface Ethernet1
5060 ip nat inside source static tcp 10.10.10.232 5060 interface Ethernet1
5060
I rebooted the router (after saving the changes to the startup config). It still doesn't work. I can ping the Sipura from my PC.
Any suggestions?
Fred
On further experimentation, I discovered something a little weird. When I have the Sipura 3000 set with a static IP address, it doesn't work. But when I change it to procure a DHCP address, it does work.
I can't figure this out. That shouldn't make any difference.
I've emailed the manufacturer and I will call the VOIP provider's technical support number when they are open. But if anyone here has any ideas about this, I'd really appreciate hearing it.
Regards,
Fred
