If only it were that simple.
Simpler, actually, grab TZEDIT.EXE from the Win2k resource kit, or there's a Microsoft knowledge base article that has a link to download it; run the program, tell it that DST for your timezone starts the second Sunday in March and ends the first Sunday in November - those are the new extended start and end times.
Then go to the Time/Date control panel, switch to a timezone that isn't yours, then switch back. Bingo.
What do you propose one do about re-occurring outlook appointments?
> (they will all be off if you do as above)
Microsoft also has a utility that will do this for you. Obviously, back up your Outlook data first.
Required to correct Outlook 2000, XP and 2003 calendar entries. Not required for 2007 but recommended anyhow as it fixes some other stuff (I forget what).
Granted, things are probably different when an Exchange server is involved. Thank $DEITY, I don't have to deal with Exchange anymore, just standalone Outlook installs.
Pat, that issue you had with PuTTY is weird. I run PuTTY at work and at home, and updated a few computers with it installed, and had no trouble. You're running a current or recent version, right?
Steve Sobol, Professional Geek ** Java/VB/VC/PHP/Perl ** Linux/*BSD/Windows Victorville, California PGP:0xE3AE35ED
It's all fun and games until someone starts a bonfire in the living room.
[TELECOM Digest Editor's Note: I am running a version of Windows 2000 which is fully up to date with security patches as issued by Microsoft. The trouble, I suspect, is the NetTime 2.0b7 software running in there also. I use my Win 2000 machine as a 'server' for the other computers here in this room (another Win 2000 and a Win 98 and a laptop Win 98). I trusted NetTime since it is Open Source software and Open Source generally is well documented and easy to handle. And my puTTY stopped working because as far as it was concerned, I was tampering with the time manually, and puTTY considers that some sort of security issue. PAT]
