Re: Should I Switch to Vonage?
May 07, 2006 0 Replies
Had you been having a heart attack, it would have actually been your
> LAST problem. And what's you option when the power goes out?
There's all sorts of levels of service. What do you do if 911 doesn't work? (What would you have done before 911 was introduced?) What do you do if the power is out? (What do you do if your phone is a cordless and won't work without power?) What do you do if you're not near a phone?
I don't see the fact that VOIP is innately a little less reliable than landline as a show-stopper. You just need to understand the tradeoffs before you dive in. Of course they should tell you. The same way as the companies that sell cordless phones tell you that in event of a power failure the phone is worthless. The same way that cell phone companies tell you that there are locations where the phone won't work.
Dave
