Re: Need Power Connector for Millenium Payphone
Jun 18, 2007 0 Replies
Im looking for a power connector for a Nortel/Quortech Millenium
> payphone in the museum's collection so that it can be shown with its
> display lighted on display. I realize that it won't be able to be used > for calls ...
> The needed connector is the one which +/- 24 volts is connected to,
> and also ring and tip and which then plugs into the the NT5U01 BR rear
> terminal board assembly. I believe the part number for the missing
> connector is CPD13S04P2.
> I realize I could solder the connections directly to the board if
> absolutely necessary, but would prefer not to go that route if the
> correct connector can be found.
> Thanks,
> Dave
> Telephone Museum of P.E.I.
Hey Dave, why can't the display be used? You could probably use a PIC to control it.
Tony
