A flash was (and still is, I believe) never intended to be passed from one
> switch to another. It is a means for the subscriber (phone) to signal the
> nearest switch in the chain.
> It appears that your equipment can serve either as a switch (PBX) or
> as (dumb) terminal equipment (CENTREX). When a CO termination is
> ground start, that makes it a trunk between two switches and by design
> will not pass a flash. When it is loop start, it is a line and will > pass the flash.
> The difference between a PBX "trunk" and a Centrex "line" is not just
> one of terminology. There are technical design differences between
> the two. This was true when there was only one supplier for the
> network and a lot of these standards carried well beyond the date of
> deregulation. The fact that they offered you a solution by changing
> cards probably means that this "standard" has been corrupted.
> One final thought: At the CO end, a ground start PBX trunk originally
> was not capable of recognizing a momentary open as a flash. Thus, any
> momentary open exceeding 20 ms (or so) would effect a disconnect.
> That might still be true.
> Has the LEC really offered to provide you ground start Centrex lines?
> At one time those were mutually exclusive.
> [TELECOM Digest Editor's Note: Actually, on my PBXtra, which goes
> under the brand name 'Total Com' and is manufactured by ACNC at the
> phone number 630-241-2800, (but distributed by Mike Sandman through
> his online catalogformatting link[and he is a good friend of the
> Digest and well trusted on the net]) you _can_ pass along a hookflash
> to the next switch down the line, i.e. the central office.
Do you even understand the difference between a _POTS_ (analog "loop start") line, and a "ground start" (aka "wink start") *trunk* line?
Does your "Total Com" connect to the C.O. with POTS lines?
If so, the fact that "flash" works with _your_ system it totally irrelevant to the question of passing flash on a C.O. "ground start"
*TRUNK* line.
[[.. balance of 'ignorance in action' snipped ..]]
[TELECOM Digest Editor's Note: It is always so pleasant to receive your replies, since you phrase them in such a congenial way, and pepper them in your own, sort of special way. I think I know the difference between loop start and ground start lines. On older, ground start payphones for example, a coin deposited would trigger a metal 'finger' like thing which would apply ground to the line. Children used to stick a pin in the handset cord of a payphone to get the same results.
The TotalCom Pbxtra device connects to whatever it connects to (mine does have a POTS line (dial 9+), an VOIP line (dial 8+) and a Cingular Wireless cell phone (dial 7+) and other 'local' extensions (dial 100 through 104.) All I said was flashing during a call, then dialing *6 causes a hookflash to be sent back to whatever switch is next in line. It does it through software, I think. You can also program the entire system (as opposed to individual stations) to have *5 apply ground. I do not know how to install that program; I have never studied it. The various system-wide programs it is capable of doing are accomplished by shorting two pins on the RS-232 connector on the bottom, then using the station plugged into the zero port to dial in the desired program codes. By itself, the PBXtra can do _nothing_; the entire unit has to be programmed from the zero port with a jumper attached through the RS-232 port, much as we used to program the old Motorola 'brick phones' by reversing two leads on the battery connector. PAT]
