Re: Hookflash and Ground Start Analog CO Trunks from PABX
Mar 04, 2005 0 Replies
Earlier today I posted a message here saying that, in regards to my PBXtra, I could simulate a hookflash to the central office even when behind the PBX. I can, but not quite as described. I said earlier:
in a call, flash on PBX, dial *6 (or 26 in rotary) then when dial
> tone returns, flash again (straight through to CO).
Actually what I should have said was in a call, flash the PBXtra, dial *6 (or 26 rotary) and that _*6 serves as the hookflash. I had not used this feature before and tested it out after printing the message. The *6 causes the PBXtra to disconnect itself from the trunk line for a half second, then reconnect itself which is the essence of the hookflash. You _do not_ do the second hookflash, since the *6 causes it to happen.
PAT
