Re: Caution: Unidentified Callers - VoIP
Jul 17, 2006 0 Replies
>> Thor Lancelot Sim>>> >>>> I suspect from the way current VoIP calls are structured that it would be
>>>> (a) very easy to spoof the number,
>>>> (b) impossible to enforce upon overseas numbers and
>>>> (c) too easy to make the number unavailable in the first place. Heck,
>>>> even the doctor's office number is "unavailble".
>>> This is all false. Why do we have this same discussion over and over
>>> again every few months?
>> Well, you don't say where you think you got your information.
> I got it from 10 years of design and analysis experience with the
> underlying protocols; that it is impossible to "spoof" calling party
> ID in properly configured SS7 networks whose operators do not configure
> trunks to _customers_ as if they were trunks to _network equipment_ is
> simply a matter of fact.
> As all the interworking standards make clear, any interworking to a
> protocol which does not differentiate between customer-provided and
> network-provided calling party identification must either use the
> supplied number as a customer provided number only, or replace it with
> the BTN for the trunk.
> Thor Lancelot Simon snipped-for-privacy@rek.tjls.com
> "We cannot usually in social life pursue a single value or a single moral
> aim, untroubled by the need to compromise with others." - H.L.A. Hart
How may SS7 are in use with a VoIP call? As few as zero for PC 2 PC.
