Re: Can I ring my own landline phone? [Telecom]
Apr 23, 2009 4 Replies
Jump to replies (4)
Re: Can I ring my own landline phone? [Telecom] open original image
One famous kind of test number belongs to NYNEX, the regional Bell
> telephone company operating in the northeast U.S.A.. In New York at
> least, there are "9901" numbers, or local numbers of the form xxx.9901,
> which result in a recording which identifies the exchange represented
> by the first three digits. The 9901 numbers may not necessarily exist
> for all combinations of first three local number (central office code) > digits.
> All these tests and services vary with each phone company; they are
> not usually found in the phone book, needless to say.
In the old New England Telephone days, I used to dial 9816 for a ringback. Not sure if the "6" could be any digit or not..
--Gene
Yes it used to be 981+last 4 digits of your telephone number in RI.
Forgot to add, 980 would do tone pad test and quiet line.
In Boston (617-266, anyway, which is served by a 5ESS), it's
113-xxxx, where xxxx is the last four digits of the number. It responds with a tone. If you tap ("flash") the switchhook at the tone, wait a few seconds, and hang up, the line will ring.
If the original poster just wants to ring a phone that is not connected to a CO line, there are several devices that can be used as a ring generator. Among other options, the "Tele-Q" is made for live stage use, or a Western Electric 118A can be salvaged from a 1A2 system.
Wisconsin's Viking Electronics (
, mailto: snipped-for-privacy@VikingElectronics.com ) offers a box that emits ring signal, as well, their DLE-200B Line Simulator, roughly $100.- last I knew.
Cheers, -- tlvp
