You're right it does come from the switches master clock, but if it is
> off, then they are not running their updates each night to the NBS or > like clock.
Hi -- Slight "correction," NBS is now NIST. Also, you can get the Naval Observatory time from either 202-762-1401, or, go to:
I know that you believe that you understood what you think I said, but I am not sure you realize that what you heard is not what I meant. -- Robert McCloskey, State Department spokesman (attributed)
