Re: Caller ID TIME For Setting Time on Regular Pots Analog Phones
Oct 26, 2005 0 Replies
Where does the time come from that analog handsets use to set their
> clock? My company's time is off by 2 min and I can verify that its
> getting the time from somewhere but where?
> I can prove it is getting the time from somewhere by setting it 1 hour
> off and calling it with my cell phone, and watching it get set again,
> problem is, its off by 2 min.
> - Thanks
> [TELECOM Digest Editor's Note: The time comes from a clock in the
> central office serving the phone. That two minutes difference most
> likely is an accumulation of a few seconds here and there over the
> several months since daylight time went into effect. Our time of day
> here comes from the Southwestern Bell central office in Independence
> which tends to 'drift' a little bit regularly. When Standard Time
> returns in the next week or so, the clock setting will get set to
> almost perfect. I say 'almost' because your caller ID device is not
> intended as any sort of time standard. PAT]
You're right it does come from the switches master clock, but if it is off, then they are not running their updates each night to the NBS or like clock.
The only good spammer is a dead one!! Have you hunted one down today? (c) 2005 I Kill Spammers, Inc. A Rot in Hell Co.
