QuickerTek 27db Transceiver for AirPort
Mar 10, 2005 0 Replies
27db Transceiver for AirPort Base Station; Adds up to 1/2 Mile Line-of-Sight Range!
If you have Wi-Fi range issues, this is the solution for you . Plus, the user can add one of these to each end of the network if needed. The transceiver is also great for point-to-point systems, college dorms, distant AP's like house boats trying to connect to wireless access points etc. Typical installations would include classrooms or fixing range problems with your ITunes and AirPort Express by adding this to the PowerBook or Desktop.
The 27db transceiver operates on all 2.4GHz, Wi-Fi systems. The transceiver is Wi-Fi compliant, supporting both 802.11g and 802.11b. and works with both OS9.x and OS10.x systems. This product is designed especially for Apple's Airport Extreme wireless systems and allows the maximum power output allowed by the FCC. Apple wireless products have RF output of 30mW; our product is 500mW.
This transceiver works on Apple Base Stations (Graphite, Snow, and both Extremes models). It comes with a 2.2Dbi antenna, but all other QuickerTek omni and directional Base Station antennas can be added.
