How to Wire an RJ45 Jack for a Merlin 206 System
Jun 20, 2006 0 Replies
I'm trying to set up a Merlin 206 system. I need to know how to wire the 8 conductor cable to the rj45 jack. The other end of this cable will have an 8 conductor plug which will plug into the 206 unit. Thanks for any help. It would be helpful to know which color coded wire goes to which screw terminal inside the jack and which color wire goes to which pin in the plug on the other end of the wire.
