OK, this is probably a stupid question to those in the know but what exactly is a "wireless" zone in regards to security systems? Is this like a motion detector or what exactly?.
Thanks.
is a "wireless" zone in regards to security systems? Is this like a motion detector or what exactly?. Zones on wired systems are simple circuits which can contain one or more sensors. Supervised wireless systems assign a single sensor to a zone. Unsupervised wireless systems…
Read the full replyOK, this is probably a stupid question to those in the know but what exactly is a "wireless" zone in regards to security systems? Is this like a motion detector or what exactly?.
Thanks.
yes. or door or window sensor or glass break sensor or smoke alarm. generally 1 device = 1 zone with wireless.
It means that the system is capable of using wireless transmitters. Sometimes it's necessary to add some modules to add wireless capability to a panel. Depends on the mfg and the model. When using wireless devices, each transmitter is a zone. If you are looking for details here, or in any tech group, it's helpful if you tell people what equipment you're working with.
Zones on wired systems are simple circuits which can contain one or more sensors. Supervised wireless systems assign a single sensor to a zone. Unsupervised wireless systems can have multiple sensors on a zone. Note, however, that almost all modern wireless alarms are of the supervised variety.
