Problem with Battery Recharging in Lynx-R
Sep 23, 2007 27 Replies
Hey...let's backup a second...did you say it was saying Low Batt...then 37? If so that's a low battery in transmitter 37, NOT the main sys battery.
Also, if you are having a problem with the drawer-type battery, I did find a diagram (finally) that shows there is a retaining screw inside the panel that looks like it holds the drawer assembly in/back against the rear of the main case.
Crash, yes my panel is flashing Low Battery right next to the AC words in the top right corner of the panel. It also says 37. The thing is that I only have 18 zones programmed and none of those has a battery problem. What is zone 37?
Zone 37 might be your 5804 or 5802 keychain remote.
Jim Rojas
Jack wrote:
Jim, I have three keyfobs and one panic button. I guess I will need to change all of them one at a time and see what happens. Thanks for the heads up on that.
If you have a program sheet handy, it will tell you what serial number occupies zone 37. The serial numbers can be found inside each keyfob for the most part.
Otherwise a panel upload can retrieve this infomation easily.
Jim Rojas (813) 884-6335
Jack wrote:
or just change the batteries on all of them...usually when one starts to go the others, if same age, will follow shortly.
Thats the 1st stage booster
