Power 832 "Low Battery" Error
Nov 30, 2005 29 Replies
Don't assume that. We had an entrie shipment that was bad. 200 12v7ah batteries, that made great paper weights.
I'll check the voltage asap... they had an orig. batt. from DCS and had one made in town that meets the specs. Both give the error when used... and this is the second 632 board I have tried... weird huh ?
i am a DSC Tech and believe it or not some panel that have been epromed (reset) by shorting the pins on chip will cause that error forever..
I don't believe you. Post your extension number immediately!!! :-)
I understand the same thing happens on some web sites (with pop-ups that last forever)...
heh, ok so sending the new board we just got a week ago back for a replacement. :) Don't know what to tell ya about the pop-ups ;p
Is this the "hot-wired" thing that lads are doing to unlock boards? How do you guys do it?
I could tell yah, but then I'd have to kill yah....:))
RHC
I choose Polesoft Lockspam to fight spam, and you?
Are you seeing the low battery thing? I hate to say this, old bean, but I wouldn't use a board unless it'd been unlocked by the factory. (If you actually have the factory method, that's a different story.)
Whaaaaaaaaat ?.....an unlocked board is an unlocked board; there ain't no difference !! And the factories don't unlock boards.....they'd rather sell you a new one...
So Mike, shall I take you off the list of the local dealers that I know and love that I do this for on occasion for no charge.....:))))
RHC
PS: No, I've never seen the "low battery" thing described in this thread....
hahahahahahahahahhaahahahaha we should be in expensive restaurants dining our lady friends! but nooooooooooooo
