Help w/security camera and controller?
Sep 26, 2005 1 Replies
Jackcsg
That camera is designed to be installed upside down. It doesn't offer "table top" mounting. The KX-HCM280 from Panasonic does....it's a Network Camera though.
I'm using a Panasonic WV-CS554 (or a very close model) w/the WV-CU101 controller.
The problem is that as a security camera it's made to be mounted above the subject. I need to mount it slightly below the subject. When you do this, though, you end up with an upside down image.
I apologize for my ignorance, but is there any way to either a) have it record it right-side up or b) rotate the image 180 degrees so I can see it right-side up? It displays on a tv, but could it be moved to a computer screen and perhaps there's software that would flip it?
The other caveat is it's also tied to a ES-488 SMTPE timecode generator, and I can't lose the accuracy of the time stamps matching.
Thanks in advance for any help! Cady
