Help identifying system
Jan 04, 2006 1 Replies
Sorry if this post is off topic.
I recently conducted a war dial as part a security audit of modems connected to our companies telephone lines.
While I was able to identify most of the systems found there are a few I need help with. It has been suggested that these may be some kind of alarm system.
If anyone recognises any of these or can give me any idea what they are, I'd be very grateful. Specific software/vendor/model details would be great.
Thanks in advance
1)
The first simply asks for a password, it allows 4 tries, Each character typed echoes a '#', including the newline.
===== BEGIN LOG ===== CONNECT 2400
PASSWORD> ##### PASSWORD> ###### PASSWORD> ##### PASSWORD> ###### NO CARRIER
===== END LOG =====
The passwords tried in the example are root, guest, test and admin.
2)
The second system is a simple ']' password prompt. You get hree attempts until you are disconnected with what appears to be a error code, or possibly a serial number.
0000004E0DD4
+++ ===== END LOG =====
3)
The third system asks for a passcode and echos '*' for every character entered, including the new line.
===== BEGIN LOG ===== CONNECT 28800
Enter PassCode ****** Access Denied
Enter PassCode ***** Access Denied
Enter PassCode **** NO CARRIER ===== END LOG =====
The passwords tried in the example are guest,test and admin.
Snip Stuff::
My opinion is that you most likely stumbled on a older CC validation system.
