First Alert Keypad replacement
Dec 05, 2006 1 Replies
I have an old First Alert FA140C alarm system with a FA250KP keypad. The programming manual indicates that I need the FA550KP Alpha keypad for reprogramming. Will one of the standard Adecom keypads work with this First Alert System? Also which Adecom system is comparable to the FA140C?
GaryB
The FA-142C does so that one might as well, only thing to do is try it and see
