On Aug 26, 2:42=EF=BF=BDpm, Marc_F_Hult wrot= e:
Yes, but fall into the category of volumetric motion detectors.
Too fine a distinction for this conversation ...........
but they don't necessarily need to be mounted underneath the floor. They have a very wide range of sensitivity settings. I use them on boat alarms and have found them to be very versitile in their placement.
Take a look at the Pulnix PR-5B. I use these also on boat alarms and they last forever. It's surface mount but only protrudes from the wall by about 3/4 of and inch. The range is only about 17 feet but it can be increased a bit by increasing the amount of reflected area. ( ie. using two or more or bigger reflectors) Also, the reflector can be covered by a dark piece of thin plastic (same as the transceiver) to make it less obtrusive. The reflector doesn't have to stay in it's supplied housing either. There's also another unit with a shorter range ..... 3 feet, I think.
Again, I haven't read the thread in great detail (so this may have already been suggested) but there are some CCTV cameras that come with motion detection capability and relay contact output. You'd need two, but mounting and disguising cameras in corners, on shelves, and possibly in normally seen household items might appeal to you also. With cameras, the "hot" areas would be able to be set very precisely. You'd only be using them as "motion" detectors, so you'd only have to hook a monitor ( old TV with a composit video input) to the cameras while setting the hot areas. You'd only need to get power and relay output wires to the cameras back to your "panel" Sorry but I don't remember which mfg has these cameras, but I think it's a readily available option.
Buuuuut .... functioning in complete darkeness would be a problem, come to think of it. Would require some sort of infrared illumination. Oh well............................... I'll leave you with the thought.
