Switch Bounce in Leviton 6291
Aug 21, 2008 0 Replies
I switched a lamp to CFL and had to replace my dimming wall switch with a leviton 6291 (relay) switch. I dug it out of the pile of old X-10 stuff, it's probably
20 years old.
Remotely, the switch works perfectly.
If I push the manual switch very deliberately, it works. If I tap it as quickly as I can manage, it works. But if you walk up and tap it at a normal rate, the relay clicks 3 or 4 times and ends up in a random state. I fear this is gonna do harm to my CFL inverters.
Closest schematic I can find is this one:
I'm tempted to put a cap and current limiting resistor across the switch. More peak current will help keep the switch contacts from corroding.
Better schematic? Better idea? No, I'm not gonna go buy a new switch, I'm gonna fix this one if it kills me.
mike
