roZetta protocols
Feb 04, 2006 20 Replies
If you want an MR26A input to trigger an output from a different (i.e. non-default) device you'll just tell it what you want, using very simple syntax. For example, with an MR26A on S1 and an ASCII device (e.g. your Lutron gateway) on S2 you create an entry (in a text file)...
[t1] default=t2 device=TW523 ... [t2] default=t1 device=JDS Stargate ... [s1] device=MR26A default=t1 D5 AA B0 30 AD=s2, (your ASCII command), [parameters] [s2] default= device=ASCII ... [s3] default= device=2414S ... [s4] default= device=PCS UPB PIM ...
There will be a section for each port. The entry on the left of = is the input and, on the right, the output. In [parameters] you will be able to specify a timeslot and days of the week when the command will be valid. There can be multiple entries for a single input so you can vary timeslots based on weekdays or holidays.
I'll create a Windows interface similar to what I did for the BX24-AHT which you can use to enter data and download it to roZetta. The BX24-AHT manual is available at...
This will be similar.
There will be another file defining events triggered by time of day with optional DST offsets. roZetta will compute local dawn/dusk based on latitude & longitude entries.
I'll publish the details on how the data is stored within roZetta so others can create interfaces.
What software do you use with it now?
I have a replacement PIC that allows the MR26A to also handle X-10 security codes, Ninja camera positioning codes and Digimax 210 (European RF thermostat) codes. It also has a bit more intelligence that the X-10 chip only sending a single copy of the code. It will require soldering an SOIC-8 chip. It's fairly simple to give the MR26A a more efficient antenna. I've published plans in the past and will include them on the new web page for roZetta.
