Linux Thermometer with DS1621
Jun 11, 2005 1 Replies
Hi friends, someone have built "Linux Thermometer" Project from
In my Windows 98SE box the sensor work very well (with VB program) instead in my Gentoo Linux Box the sensor put only -60.000* or
58.876*...
Can you help me? :\\
Thanks
I haven't built the circuit or looked very closely at the software, so this is just a wild guess. Run at the command prompt: $ stty -F /dev/ttyS0 -hupcl before running the thermometer software. (Modify for the serial port you are using.)
I'd appreciate hearing if this solves the problem.
Regards, Charles Sullivan
