Home run -- advice needed
May 23, 2005 1 Replies
I just moved into a new townhouse that I had all the coax wired to the garage. I'm trying to do a home run, where I have the cable box/Tivo in the garage, split the signal to 3 rooms. I am using Xantech injector/coupler to send the IR signals over coax.
The home run works and infrared works, however the picture quality is poor. I assume I need some sort of amplifier. Can someone reccomend one at a reasonable price?
Thanks!
-Mike
How about free? Call the cable company and tell them the picture is bad and they'll come out and add the amp if that's what's needed. You should also make sure that the connectors are all sound and tight. If you do need an amp, search "cable amplifiers" on ebay and you'll find pro units like Electroline, SA and Motorola at good prices.
From: snipped-for-privacy@gmail.com snipped-for-privacy@gmail.com
