Advice needed on simple whole-house audio system
Jun 24, 2006 1 Replies
I would like the expertise of some of the posters here on how I can build and install my own (simple) whole-house audio system. My requirements are fairly easy...I only need one zone, and the indoor audio will consist of one (mono) speaker in each of three rooms. The outdoor audio will be three pair of outdoor speakers in my backyard. The audio source would be whatever is coming out of the line-out ports of my family-room A/V amp, which would be the MP3 I'm listening to, or the movie I'm watching. The interior sound quality just has to be 'good enough', that is, some background noise for dining or party guests.
I have posted a diagram of what I THINK I should do at:
I had planned on installing a panel in the wall behind my family-room stereo, to take the line-out of that amp up to my home office closet and into a stereo amplifier. From there, the amplified signal would go up into the attic to a distribution panel. There, the amplified signal would be split into the various cables to go through my attic, down into the walls of 3 rooms to volume controls, and then back up into the attic to mono, ceiling-mounted speakers. Same thing for the outdoor audio, but into pairs of stereo, outdoor speakers.
I have a few questions...first, is this plan okay, or am I underestimating what needs to be installed? It seems less complicated than I expected, even for what I think is a simple system.
Also, I will use high-quality cable to carry the amplified signal everywhere it needs to go, but do I need to also use high-quality cable to carry the unamplified signal from the family-room source to the amplifier in the office closet?
Finally, I had read that I should use 'impedance mathching volume controls', but I must admit I'm not sure what those do for me. Do they ensure that turning up the volume in one room won't diminish the volume in all the other rooms?
Any help that can be offered would be greatly appreciated!
--Alex
Impedance-matching compensates for the impedance drop of using multiple sets of speakers in parallel. This feature allows you to add more speakers without causing harm to the amplifier.
-- Bobby G.
