First to build the XTB from a kit...!
Jun 09, 2006 3 Replies
Jump to replies (3)
Hello everybody!
When I read the thread about the XTB, I was instantly excited!
I must have more signal-suckers than ANYBODY, and my X10 reliability was very poor. So I pretty much yanked all my X10 (watch for it on eBay someday...) and replaced it with Insteon.
All my outdoor lighting uses X10 wall-outlet modules. I guess I'm speaking of the SuperSocket SR227...
Also I have the X10 dual floodlight motion sensor. PR511...?
Since there are no Insteon equivalents (yet), I'm forced to keep them X10.
So I quickly decided to buy Jeff's XTB. Brute force sounded like just what I needed.
I found out that the PCBs were late to arrive, but the parts were already kitted. It would take longer to get one if I ordered completed units so I decided to go kit. And if one is good, two is better! With the money I saved, the second was a real bargain, etc, etc. I rationalized it, then placed my order.
Jeff assembled one before sending out any. Make sure there were no surprises, etc. He updated the product since the two he sent out for review: he replaced a couple diodes with Schottky type...
Satisfied he sent mine out on Monday (from New Jersey) via Priority Mail. I live on the opposite coast in Oregon, and I got them today.
It went together easily, and the PCB was of very high quality. The silkscreen was also very good. I was unsure of one component, so I emailed for help. The answer came quickly and it turned out I had it right all along.
He also informed me I was the first person to complete one of these from kit!!
Oh yeah: While awaiting delivery Jeff alerted me that the change he had made required an additional component change. R9 was a 51-ohm, now it should be a 10-ohm instead. 5 for a buck at my local Radio Shack!
Knowing this I had the corrected value on hand for today, and substituted it on the first build.
How does it preform? Well I haven't had time to give it a battery of tests.
I can say it seems to work great!
My driveway floodlights are M11. With a palm pad I could control it (through the many 751's around the place.) But if I try using a Maxi-controller the signal doesn't get there.
Plug the same Maxi-controller into the XTB, then back into the same plug...
NOW the signal got there! Brute force? Works for me...!
More later, as I learn more.
For NOW, all I can say is I endorse the product - and the man. Jeff has it going on...
Thanks to this newsgroup without which I would not even KNOW about the XTB.
Thanks to Jeff for the concept, and bringing this fine product to market! Kudos!!
Buy yours. I'm sure you won't be disappointed.
I will warn that this is an advanced kit and you need skills to build it. He engineered it well, and it went together easily. Keep in mind I've been doing electronics all my life. It was a tightly packed joy to build but if you have ANY doubts - order it assembled and tested.
Jack :)
Glad to read your review. Mine were shipped the same day as yours but getting to Hawaii takes an extra day so I'm hoping to receive them tomorrow. I ordered one assembled and one kit. Assuming they arrive tomorrow I'll install the assembled one right away and build the kit this weekend. I've been soldering kits and other circuits together for over 45 years (since 5th grade) so I'm not expecting any trouble. I too have my 10 ohm replacements on the bench and ready to go.
Like you, I replaced all my X10 stuff - with the exception of two Appliance Modules that are buried in a watertight enclosure. How has your Insteon experience been? What are you using for a controller? I'm anxious to compare notes as I'm having some issues with the 2414X Translator.
Me too! I was certain that the reports were going to come back positive. I can't wait until Bruce gets his because IIRC he has some real black holes and growing issues supporting his X-10 based Stargate that the XTB should be able to solve.
As for the power of the XTB all I can say is it's as if I was playing Doom for years with just my bare fists and someone said: "Psst, wanna buy a chain gun?"
"Ubetcha!"
-- Bobby G.
Hi Everyone,
I am new to your news group. Jeff referred me to your group. I was so impressed with the XTB kit I got, that I told Jeff I would report to any group he wanted me to. I got my kit Thursday afternoon. By friday morning I was getting X-10 signal like I have never seen before.
I have a 3000sq. foot home with a detached garage. Computer power supplies, home theater system, and whatever my daughter and son-in-law have plugged in. Well after adding the XTB to my Lynx10 PLC I average
3.5 - 5v or more (Full scale on my detector) around the house and 1.5 - 2.5 volts in the garage. My custom circuits that report status back, like my sprinklers haven't missed a beat. My low voltage yard lighting also hasn't skipped either.
If you are not an electronics circuit builder don't order the kit. You must know how to id the parts and be proficient at soldering. Spend the few extra bucks and let Jeff build it for you.
Other then that this is a super product.
Ta Da Brad
