ELK m1 in Europe
Dec 19, 2011 1 Replies
Hi All,
Does any one know if the ELK M1 will work in europe, besides the obvious power supply question? I'm considering buying one (board only) an get the rest of stuff locally.
Regards
Since the Elk runs off of 16VAC, all you would need is a step-down transformer for your local line voltage.
I love the ElkM1! I bought it and installed it myself.
If you do end up getting one, install the EOL resistors on all of your zones. It is optional, and called a professional installation element, but its a nice feeling when you check the zone status and see a mid-range voltage instead of a short or open.
Hubert
